I have a 1974 Evinrude 135hp. If I start and let idle and then put in gear and put throttle down to plane it will take off normally for a few seconds and then bog down. I can also run at intermediate speed and cover the choke plates and it will speed up for a while. The upper carb seems to function properly. I did take the carb apart and clean up and blow out jets which seemed to be clean for the most part. This procedure did help with idleing as it wasn't firing on one of the barrels before this was done. I can repeat the procedure of idleing and then taking off well for a few seconds. My thoughts are that the fuel chamber is running out of gas. Float is empty when shaken. Will needle getting hung up or float adjustment cause this problem - (fuel pump doesn't seem to fit here) Thanks for your help
