1.6 Litre OMC shift linkage location
Davec4436
I have to replace the water pump impeller. To remove the lower unit, I have to loosen the shift linkage screw that engages the shift shaft. Where is it and do I have to remove other components to get at it? Diagrams or pictures would be big help.
boobie
Re: 1.6 Litre OMC shift linkage location
You should get an OEM Factory Service Manual if you are going to do this work yourself. Maybe somebody else will chime in.
