I started having engine trouble the other day,I replaced the fuel lines under the cowling,and the primer bulb, and the lines from bulb to sep, and sep to engine.I also replaced the fuel filter under the cowling, and sprayed a can of decarb, but I'm still having issues.
At idle it runs good, in gear it seems to run a little rough at low speed,I can get on plane gradually, but if I try to nail it I get no response at all.My shifter seems to be really tight or needs some lube,in neutral I can rev it fine, but when pushed in and in gear pushing it forward is really tight, I don't know if it has any bearing on the issue.
