I use my boat every weekend, weather permitting! My 88 special Johnson outboard will jerk & pick up speed, then slow back down to what i was cruising every few seconds in nuetral & idle speeds, at high speeds it's smooth sailing. It will also sputter as if it wants to stall out when in nuetral/idle speeds, so i to try to squeeze the gas ball and it will stall out. I changed all four spark plugs, emptied the water/fuel filter seperater and it was full of something like gas or water? My next step is to run all the gas out and get fresh gas and do a sea foam gas treatment. What else should I be looking for to stop the jerking? Please help the Red fish are calling my name on the flats!
