Re: 1975 Johnson 85HP--Tach Question
If its similar to the '75 Evinrude 85hp and the controls.... There will be a grey wire running from the motor through the electrical connection that goes to the control box. Mine was just capped off once I got the control box open. Splice that line in with your grey wire and you'll be good to go (fyi... try to keep the routing of that tach wire away from main battery wiring that's also hooked up to the motor. Sometimes you can get weird interference from those wires as well as fish finder transducer cables, trolling motor cables, etc.).
