leslielbk
- Jun 8, 2011
- 56
I finally got my motor repaired, and now I need a battery. They run about $100 +/-, and I saw a post here that said the motor really doesn't need the 650 cca battery I was about to buy. Is it possible I can use a smaller battery and charge it up between uses? The posts were from 2003 so I thought I'd double check and maybe get even more advice. Thanks!!!
