I have had this boat & motor for 6 years. I used to be able to get 5,000+ rpm and 43 MPH. Last summer it started running 4,000 max and only about 32 MPH. I would also occasionally bog down a WOT and wouldn't run over 2,500 to 3,000 RPM. My mechanic has replaced both coils, rebuilt the carbs, new fuel pump, filter and water separator. The primer & fuel lines from the tank to the motor have been replaced. The VRO was disabled before I bought the boat, and I asked the mechanic to check all the lines to make sure no air leaks. He has checked the plugs, timing, and electrical system. He has also ridden with me and checked for overheating with an infrared gun to see if it was running in safe mode. Also, I have not changed props.
Any ideas what to check next. We are pretty much stumped. Thanks!
