Hello. I have a 1984 Johnson V4 outboard with VROiling system. When I start it and run at WOT it will run good (about 30-35mph) for a brief period but will eventually bog down (engine loses RPMs and eventually shuts down despite the throttle lever being still full forward). Bought the boat used just last summer so did some work over winter to hopefully fix problem. Changed plugs, pulled gas tank and washed it and let dry (no corrosion in tank but there was varnish in bottom--- all cleaned out now), replaced fuel primer bulb and put new inline see-through fuel filter on. All fuel lines are in good shape. Started boat and still same problem. Runs real smooth at WOT but bogs down. Re-pulled plugs and left 2 plugs are dry with light tan deposits. Right 2 plugs are moist with black deposits. Next step in my head is to check fuel pump diaphragm for holes and remove air cleaner box and clean carbs. Was also going to check the color of spark when engine turned over. Dont' know if anyone else has any suggestions other than this??? Very frustrating as I live about an hour and half from lake so its frequent, expensive guesses at problems and then break down in the middle of lake... luckily my buddy has been with me recently to tow me back. Thanks for any input.
