Mikeevans129
- May 11, 2012
- 6
Hi,
I've removed my lower unit because prop won't turn when engine is in gear and I've discovered that the top of the driveshaft has sheared resulting in 2 questions......
1) How do I access the 'top' part of the drive shaft to remove the broken bits?
2) how do I remove drive shaft from lower unit in order to fit new one???
Any help most welcome!
