Ok then open her up.
The earlier prop shaft seals will have a 0.625" Bore, 1.254"OD, 0.313" Width, Part number 302495
The later prop shaft seals will have a 0.625" Bore, 1.128"OD, 0.25" Width, Part number 313284
I can guarantee that they dont all use the same seal kit.
Ok dumb question but how do I get that seal out of the bushing assembly thing
Are you sure about that!
I can guarantee it, what do you think?
Okay so I opened it up and the brass bushing has grooves in it as well as the prop shaft. Really pisses me off cuz the owner has a 150 dollar limit and I'm already there in parts. I was told it was a rebuilt lower unit but that's not the case. What would you guys do?
After another look the side of the prop head that faces the prop is out of round. This piece looks like it is stainless not aluminum and possibly part of the seal, is the prop shaft seal rubber and metal or just rubber? Also zephyr the only hole in the thing is for the pin the line up with the lower unit side.
