Just got a center console with a older '76 johnson 200hp motor. I lowered the boat into the water off the lift to cover the lower unit and started engine. I notice that water is squirting out the seam where the lower and top unit is joined on both sides. Since I dont know much about this motor is there a gasket or something for the lower unit or is it just the lower unit needs to be tighten on the four bolts holding the unit on??
Also my trim works kind of, but is sluggish (?) and doesnt seem to work good when boat is running. Any ideas?
And the final question is I thought I might want to put a newer motor on the boat, say like a Honda 130 4 stroke, but the guy at the Marina said that I couldnt unless I built the transom up ?? Is there a motor I could put on to replace the Johnson 220 hp with building up the stern?
Thanks in advance.
Thanks in advance.
