Hopefully easy question about water pump 55 hp 69 Johnson
Bigmykesboat
When I put the foot back up in the motor the two plastic three inch tubes sticking out of the top of the waterpump housing slid easily over the two pipes in the motor. Do they need to be a snug fit?
MH Hawker
Re: Hopefully easy question about water pump 55 hp 69 Johnson
They are nornaly a slip fit but yes should be snug enough not to leak a lot.
Daviet
The plastic tubes are actually used to align the water tubes into the water pump. The sealing takes place by the grommets in the water pump housing around the water tubes.
