Disconnect the shift linkage at the lower unit, can you shift the linkage going to the lower unit and have forward, neutral and reverse?
If so you need to have the lower unit in neutral, attach the shift rod and adjust until the shifter is in neutral. Then move the shifter through the gears and see if you have them when the shifter is in the proper position. You might have to spin the prop while shifting.
these are the instruction could some one please explain to me step by step sorry but my brain is not working lol thanks
