Re: Injector cleaning
Never seen ficht injectors blocked up with crap. Seen them fail. Seen them drop pintles. Someone else may have a different experience. Your best bet is to get someone with EVDiags to connect to your engine and change the richness/leanness of the injectors, in the water, with a load to see if they can identify one or more injectors causing the problem. I don't even know what model you are talking about. Also, have the same guy check all of your values for TP, system voltages and etc. The bogging down can be accounted by more than the injectors being crapped up. DFI is crap. I have sent EMMs to them and they have failed multiple times to fix the problems. They are more trouble than they are worth IMO.
