Hello all,
This is my first post. I?ll try to be as direct has possibly.
I?m looking at a boat that is fitted out with a "1997 Evinrude 200HP Ocean Pro" The mechanic has reported that the compression test is 90 across the cylinders. Is that low for this engine?
I thought that the compression should be closer to 100-120 across the cylinders. I?m trying to find the manufactures compression statistic for this engine, so if anyone knows those numbers it would also be helpful. Is higher better when buying a used engine?
The mechanic that has been maintaining the engine said that the engine is a ?LOW Compression model? Evinrude.
Did Evinrude make a low compression model ?
Thanks again for any help on this.
