I am converting this motor to remote control and noticed there is an electric primer system listed in the part list for my year motor. I would rather go this route instead of the electic primer soleniod. My questions is the 1993 and up carbs have a primer nipple on them and I can't find one on my carb. How do you connect the hose from the primer to the carb? Also, do you need the remove the choke butterfly when you install the primer system? Thanks
