Re: 3hp 1961 3hp johnson twin cyl
Thanks for the info, will check the compression tomorrow. The exhaust cover is that the long one on the side? There must be 6 bolts or more in it? There is also a smaller one that has some brass reeds. What would the pin holes be in and if there are some these are easly replaced?
