BassBumNut
- May 9, 2012
- 4
I have a 2004 175 Hp Johnson that I am stumped on. It has had new power pack put on. It has had new plugs, wires and re-carbed. It runs great no rough idling or while powering up. It used to get up to 5500 rpms and run 55 mph plus. Now it gets about 43 mph tops. I thought that maybe it was a fuel issue anyway so I have hit the key choke while running and it had no affect. I also have pumped on the bulb while running at full speed and it had no affect (Primer bulb was tight and full). It does not miss hit and its firing on all cylinders.
It has been to the shop and they left the cables not tightened up. I think they are in correctly and have bypassed them just to check. It will rev up to 6000 RPM's not in gear. I am at a loss of what to try next.
I have had a bad stator before and I do not think that that is it( not the same symptoms)
I do not believe it is a fuel issue because it will rev past 6000 rpm's in neutral.
What do you all suggest that I try next?
