Have an issue with my 88 spl outboard and can't find any one else who shares the problem. The engine runs great off the trailer. Starts great, idles and runs across the lake right just as it should. We drift fish so once we find our area, the engine is shut off for maybe up to 30-45 min. The problem is when you try to restart. The engine will only restart by lifting the fast idle lever wide open. Once the engine starts and cleans out, it wont idle but you can get across the lake. It will continue to do this the rest of the day. Take the boat home, let it set a week, and it does the same thing next week. After this week I pulled the plugs (new ngk's) and what I think is cyl #4 (port side lower) is fouled. Is there anything different on cyl. 4 that would cause this. thanks for any help!!!!! 3d
