Re: Video of Compression & Spark Test on 1988 30HP Johnson Outboard
It's my understanding you need to ground or load your coils when testing. I read that leaving a spark plug wire disconnected can damage the coils or power pack.
i agree, the coil not being tested should be grounded. you can get away without doing it sometimes....but its not worth the risk of frying an expensive part . jmo
Yes, you should start your own thread.
You can just use a jumper wire and ground the other plug wire to ground if you are using a single post spark checker.
