Hello,
I have it opened up and would like to change the oil. What grade oil and how much of it? I read the secretr file that recommends the fill pump. Is there a way to do it without the pump? Also, are the replacement hex head screws only available in the boating store? Can I try regular hardware store?
Also, the water pump area is very dirty and oily inside (as well as many other parts of motor). What should I use to clean it?
Thanks!
Hana
Thanks!
Hana
