Hello again..
I have checked over my impeller and it is OK...put it all back together to try it out and mainly steam comes out of the outlet opening with spurts of hot water..and then after a few minutes the engine hot light comes on..
The thermostat is opening OK but I dont think there is enough water going thru' the cooling system...is it possible there could be a blockage in the tubes..? I know that the engine was run without the filter on the water intake...so does anyone think that debris could be in the cooling tubes..? if so what can I do to clear them ..?
Thanks Derek in BC Canada
