duckland23
- Apr 23, 2012
- 175
I was wondering How the pressure tank works . My tank when I press in the fuel part on the hose it squrts gas out of it will that mean its working right to get fuel up to the carb on my evinrude fleetwin 7.5 hp 1957 . Im rebuilding the carb and was wondering if you had a leak from the tank anywhwere on it will it affect the way the motor will run or for fuel devlivery . Im having a problem keeping the motor running , it will only stay runing on fast idle . So if im leaking air from the tank or sucking in too much air will this make the tank not work the way it should . Im asking this before I buy the gasket kit for the tank . I bought the carb rebuild kit and did that , but am waiting for the lead shot for the welch plug , I ordered one from ebay for 2.00 , my carb was missing it and the part list showed it in there . So I think thats part of the problem too . But I heard that if your not getting a good seal on the tank that can cause a problem, am I right .
