Engine will not start unless I manually flip the red handle choke/primer(term?) behind the air silence up (not sure if cold weather lately have to do anything with it.) If I manually choke the engine by pushing in the key when starting, it would just cranks and cranks. However, flipping the manual red primer/choke? up and it starts right way. I'd then turn the lever down after a few seconds and it would starts fine with the key afterwards.
Is there a way to test if the key choke is working ? Or is something needing replacement on this engine ? Thanks.
