anyone know of a good spot to tap in a fitting for a tell tale on a 76 evinrude 35 horse? i put one on my 76 70hp at the top of the water jacket but the 35 seems to not have enough room there.....thanks
Re: where to tap in tell tale on a 76 evinrude 35hp?
If there is not enough room at the top of the head or block, take a look at the exhaust cover.
Take a look below, it's a newer engine that has a tell-tale from the factory, #48.
could anyone post a pic of a newer motor where the hose comes out of the block, it would be much appreciated i think i have a good spot but alittle hesitant to drill a hole into the engine unless i know for sure
