Hi,
i have a 1998 johnson 15h 2 stroke and i have removed the bottom leg and wanted to know how to reconnect the gear linkage.
I have already reconnected it once but when i went to change the gears they were in the wrong position.
So i need to get the linkage set in the right position before re-assmbling. The gap between the two casings only leaves a 15mm gap to re connect.
Can anyone help on this matter please.
Thanks.
Thanks.
