My '03 Johnson 15hp 2-stroke has started a fit where it runs like normal at wot then periodically loses power. Doesn't miss or sputter, just slowly loses power. So far if you let it idle back down then take off again it gets its power back. Does this several times a day. Seems to be mostly after it warms up. Pumping up the ball does NOT improve things. Any thoughts?????
