corradohome
- Jun 16, 2008
- 3
My primer solenoid works occasionally. When it works (it clicks) my engine starts fine. However it doesn't consistently click when the ignition switch is pushed in. If it is working and my engine starts but if I turn the engine off and try to start it again the solenoid doesn't always click when the ignition switch is pushed in. Any suggestions? Also, would it be common for the solenoid to stick and not work sometimes????? Also, I checked to see that the solenoid was getting power when the switch was pushed in and it is.
