Charles King
- Nov 23, 2009
- 37
This control station has a toggle switch under the key starter switch. Not shown on any parts diagram for johnson/evinrude. Since there is a "horn" in the control station, is it a test/activator?
These control station parts diagrams only show one cable.
My urgent problem is that there is no information that i can find as to how the two cables,throttle/shift-neutral,warm up lever is installed and adjusted. It also has tilt/trim control in handle which is simple and works fine.
I can move the control handle hard into neutral and crank over o k. It makes the neutral interlock start switch. Handle will not move to forward position, but will move to reverse position.
I have wasted money on a clymers outboard shop manual for 48-235 hp**1973-1990 motors. Not much help![/size][/b]
