I picked up a 1956 fisherman, model number 5512, serial number 13300. It came with a cruise a day tank. I think it's been sitting for about 15 years. I have replaced the spark plugs, replaced the gaskets and the dual line on the tank.
I ran into a couple of problems:
1. The tube that runs down into the tank that has the filter on it, seems to be frozen up. I can't get air through it either way. I currently have it soaking in some PB blaster trying to free it up. Is that what I should be doing? Do I probably need to purchase another one? Can I purchase one?
2. The fuel lines that run from the carb to the connector that hooks to the fuel line that runs to the tank are cracked and need to be replaced. What kind of fuel line should I pick up? Is that something I can buy at a marine shop, or online? Can I replace the existing clams with normal number 4 hose clamps, or should I try to use the ones they have. They look to be original.
I am new to this, but am really excited. It seems like a lot of fun.
Thanks for the advice.
