DC20
- Dec 5, 2007
- 361
So on my new to me boat the gear lube looked fine before the sea trial and was milky afterword. PO had tightened the screw but when I loosened it, I would have had it a bit tighter. Anyways in the manual it talks about a 60 and 90 degree looper, I don't know which I have to reference how to disconnect the shift rod. Pull the pin at the bottom or disconnect the linkage on the side? I wanted to replace the water pump and inspect the seals.
Model J150PXEES
Serial G 04665683
Model J150PXEES
Serial G 04665683
