txbandit44
- May 11, 2008
- 182
OK I set this all up and got all the wires connected correctly and found that the rectifier was bad. I got that replaced and now the tach needle moves
So excited it was working.
It was set on 3p and it was shoing that I was idleing at 2500 to 3000 rpm. I figured i needed to move it to 6p and it now reads 1300 to 1500. HOW do you know if this is accurate or not? This thing has a calibration set screw but what the heck do you calibrate too. This is suposed to tell me what the engine is doing. Not me tell it.
Any help is appreciated.
Also I guess this runs off of the charging system. How many poles does the 3 cyl stator have. That may be part of my problem.
