reiddo1
- Jan 17, 2012
- 166
My 1979 200 hp V6 is grinding in reverse; I have tried adjusting through the remote control cables with no success. With the motor stopped and with the selector in the reverse position, turning the prop by hand will actually turn the flywheel most of the time, but some times it will slip. On the other hand, with the engine running and with the muffs on the blade will not slip. However with the engine in the water the grinding occurs. All is OK in forward. I can buy a foot from three sellers. One is a 1982 140 hp v4; the second is a mid eighties ocean pro V6 and the third is a 1996 150 hp Vindicator. I have looked at the part numbers for each on marineengine.com but there is no match to my V6. Is it possible that even though the part numbers don't match, that the pieces will fit? All comments will be appreciated.
