Re: 1967 evinrude sportfour 60 hp motor tilt
If you're speaking of the two shock absorbers (not tilt cylinders) that are located beteen the transom mounting brackets, you'll need to take the engine off the boat and lay it down on its back, then start taking that assembly apart.
