Re: HELP AGAIN...Johnson TN-28 Clutch and Clutch cable
Ok, I don't have the exact parts book for your motor, but this is very close.
#34 spring and sleeve assembly is the shock absorber. More on that later.
#36 is the pinion shaft assy
#35 is the neutral clutch spring. #34 and #36 are two hubs with #35 wrapped around both of them. As the upper hub rotates, friction drags the spring with it. Friction between the spring and lower hub cause the spring to drag the lower hub along with it. The harder the upper one pulls on the lower one, the tighter the spring wraps. So the whole assembly is rotating as one solid unit. BUT, when you pull up on the clutch cable, a lever pivots to get in the way of the tab on the top of the neutral spring. That causes the spring to unwind just enough to lose its grip on the upper hub-----that's neutral "gear". Allow the cable to retract, the lever moves out of the way of the tab on the spring, the spring winds tightly on the hub again, and the whole assembly rotates---that is "forward gear".
Now, separate but related is the shock absorber. There is a very strong spring inside the #34 spring and sleeve assembly (that's it sticking out the top of the spring and sleeve assembly in the picture, and covered by the #33 retainer). The strength of the spring causes much friction between the spring and the sleeve, normally rotating as virtually one piece. There are two flats on the drive shaft, which mate up with a double-D hole in the top of the spring. So, the drive shaft drives the spring, and the spring drives the sleeve (which drives the neutral clutch assembly). When you hit an underwater object, the spring winds up enough to lose its grip on the sleeve. That allows the drive shaft to momentarilly keep rotating without driving the sleeve-----in effect releasing the drive shaft from the lower unit. In other words, it "absorbs" the shock of hitting the object.
If either of those springs are broken, you won't get any drive.
Forgive me for this dumb question, but we aren't dealing with a broken shear pin in the propeller-----are we??
