nightimefishn
- Jul 27, 2009
- 54
Hello all,
I have a 2000 200HP Johnson Ocean Pro and am using my older pre 1996 wiring harness. I purchased the adapter kit Part # 176345 and am able to get the engine running. My question is what would be the easiest way for me to convert my older 3 wire tach (purple,grey and black) control cable in my console to the 8 pin system check tach? Sorry I am not in front of the boat right now and am probably missing something or not having all of the information but I am sure someone on this awesome board has been down this road. I'm guessing I will ned some additional plugs or adapters to get the system check lights working. Can someone point me in the right direction if there are adapters out there I can get or if I should buy an 8 socket connector and wire it in myself?
Thanks so much
Thanks so much
