jpatterson12
- Sep 2, 2009
- 24
I have the gear case apart on my '65 9.5 hp Seahorse. I can see from micro fish that there is a seal at the gear case head, along with an o-ring. Does anybody know if I need a special tool to remove that seal from the gear case head? Holding it in my hand, I'm not sure how it's supposed to come apart. The gear case head won't slip off over the prop shaft, neither will reverse gear. Never had a gear case apart, so I'm treading on new ground.
