Evinrude 8 hp help, reverse adjustment?
kodibass
Master Chief Petty Officer
Hi I have a 1991 ruddy 8 that the PO says pops out of reverse gear, but if he holds his hand on the shift handle it wont pop out of reverse, operates fine/normal in fwrd gear, so my question .. is there a adjustment some where to to tweek the revers shift rods lever etc. or is the dawggonedoggone. any help much appreciated.
boobie
Re: Evinrude 8 hp help, reverse adjustment?
Sounds like a bad dog and gear.
kodibass
Thanks' yea that sounds like a good idea. I just made the tool to pull housing.. I'v done it before on a 9.9 its just been a while' should be about the same. (I hope)
Haffiman
Bearing house attached with 2 screws, but there stops the similarities.
