Hey all New here . So I got this motor been reading the form an seen that you can use SAE 80W-90 gear oil . No boat shops around me so I just want to make sure I can ust that oil. Reather green to boat motors tho. Great forum so far!!!!!!!!
Walmart MIGHT have it, but probably not. It will specifically say for electric shift gearcases. If you absolutely must, use Dexron Automatic Transmission Fluid till you can get the right stuff. BTW, at Evinrude and Johnson dealers Type C is now called "Premium Blend Gearcase Lube". Not to be confused with other brands called "Premium Blend". Not the same thing.
Ok drive 4 Hours to pick up sum Type C . Drained the old oil filled the lower leg up run now she runs good. Sum oil now leakin out the prop. What is the seal in there like to change now?
