1st time posting... When i turn my key to the On possition my controls warning horn (part#585994) has a solid tone. looking around some threads it seemed to be the VRO from what i was understanding. so i disconected it the alarm still sounds. i then located my temp from one side and the alarm still sounds! I then removed the horn to test it. the horn test out just fine. so i have no clue. the problem is happening as soon as i turn the key on! so i cant see how the temp could be causing this! the motor runs just fine im spitting water out the back and its not real hot at all!
so i want to back track from the horn to the motor to see if i have a short some place. does anyone know what each wire on the horn is for?
i marked what i think each is for.. please correct me if i am wrong. thanks
