I have been having problems with what appears to be no fire on the number 3 cylinder (bottom one). The way I found it was by just pulling off the plug wires while it was running. Both of the others cause the motor to die but not with the number 3 removed. Then I checked for an ark and found was not getting one on 3. Replaced plugs and put in new plug wires, still no ark on 3. Found out that if I let it warm up a while it will eventually start to ark on 3. This make me start to research it on this forum and it seems to be a common type of problem with many possibilities. I today cleaned all the carbs but do not believe that will fix it. I am also going to start running no ethanol to see what that does. I think it is the coil and am willing to buy one and change it out. The problem is that it seems that all of the coils are connected at a connector at which I cannot remove the wire and change only one coil. If that is true I will have to replace all of the coils and some other things, of which I do not know what they are, that I do not think are bad. Can I change only one coil and if so how. How do I get the wire out of that connector or do I cut it and just reconnect the new to the wire cut? Please help me. I want to go fishing and the walleye are starting to run here in tennesee.
