Outboard is having a hard time getting on plane. It died a few times maybe 30 to 45 minutes then starts right at and runs fine the rest of the day. Any suggestions of the problem?
maybe fuel problems..maybe bad gas...hard to see..you will have to do some trouble shooting..next time it happens try pumping the bulb and see if that helps.
