DavidKnapp
- Jan 27, 2012
- 17
Rebuilt both carbs ,thinking that was my issue,put a water separator in system,the motor will only run 22,000 rpm max.
There is no mix fuel air valve to adjust,checked compression 105 on three cylinders 110 on other ,all 4 plugs are very wet after running ,is there a way to adjust the carbs ,or is it a something electrical ?
