The engine mount on this is model #15034 1961. I have now received, from two different sources, OEM part # 306210, baffle plate. In both instances the port center bolt hole is not there. It is a lug extending from the port side of the baffle plate with the bolt hole thru it. There is a lug on the opposite side of the baffle with a bolt hole through it which is redundant. The two gaskets that go with this baffle are correct. Can anyone enlighten me as the what the **%^ is going on.
Thanks guys.
Thanks guys.
