1964 Evinrude 60hp M#60453s S#E03855 wiring assistance or diagrams ?
sapos07
I am trying to figure out if this Model and Serial for this outboard has a wiring diagram out there. Also does this outboard come with a charging system ! I'm good w/auto's...boats are new and fun. Just need some wiring direction ! All or any will help...thank you much !! :eek:
Joe Reeves
Re: 1964 Evinrude 60hp M#60453s S#E03855 wiring assistance or diagrams ?
Need to know..... Is there a gear shift lever on the port side of that engine or not?
On that model, there should be a good size plate on the front portion of the swivel bracket just below the carrying handle which has the model and serial number listed. Also, there may be a small quarter size core plug on the powerhead with those same numbers.
If a generator exists, it will be on the opposite the electric starter on the other side of the carburetor with a belt running from it to a pulley on top of the flywheel.
What do you need to know about the wiring?
F_R
Joe's question seems to be asking if it is manual or electric shift. There was no electric shift 60hp motor in 1964, they were all manual shift. The model # 60453s was supplied.
The rest of the reply is correct, a generator was an optional accessory, opposite the starter.
Joe Reeves
FR.... For some unknown reason, my mind was locked in on a 40hp, apparently a senior moment.
sapos07
Thanks guys...there is a belt driven piece of equipment coming from the motor head area ! But in the power block there is a diagram under the lid...it's showing the brown,yellow and blue wires need not be connected...they have numbers on them...it seems like the ALT/GEN system has been taken out of the loop ? I feel that if I have the Gen..then why not use it !! So if my thoughts are correct then i need your Veterans wiring knowledge to get threw this...what info do you need to walk this 5yr old threw this ? I can load pictures and give great descriptions....????
BonairII
I've got a wiring diagram of my '67 80horse...if that would help let me know.
Joe Reeves
If the engine had a generator, there would be Two (2) belt driven devices on that engine.
A generator would be right alongside of the carburetor.
The belt driven component to the rear of the engine is the ignition distributor, either a magneto or automotive device.
