Re: Converting from VRO to alternate pump
Part # 18-7352
For: 25-55 HP 1976-89 ( non VRO ) ...was told by a local shop that this pump will work on a 140 motor...it has been on my boat for a year now an no problems at all.... just make sure it will bolt too your motor....I pluged the pulse line on the block that went too the vro and took out the screw that will allow a fuel pump too be bolted to the block....i have some pic's of this set up on here some where.[/QUOTE]
Not a mechanic, so possible dumb question - I'm trying to replace a cracked pump on a 120vro that was converted a long time ago, but can't find a number on the pump and can't find a three-line pump online anywhere that looks like it. Pulse line is currently connected and pump is mounted on a homemade bracket. If I replace with part# 18-7352 and plug the pulse line, how does the pump get pulse to operate properly? Can anyone suggest a different pump if #18-7352 is not the one I need? Got a pic of the pump, we'll see if it attaches...
