My primer doesn't work, then again it apears to be working. Let me explain.
When my motor is cold I pump up the fuel bulb tight and hit the starter, I push in the key to activate the primer and I can crank and crank and get no fire. However if I take a spray bottle and spray a little fuel mix in the carbs she fires right up and runs great. This would tend to make me believe I have a problem with the primer. However, when the motor is at idle and I push in the key it stalls the motor which would make me believe the primer is working fine......Any ideas?
Also if I turn the red knob on top of the primer 90 degrees when the engine is cold she will start right up. This sorta has me stumped.
