jrynearson
- Mar 16, 2012
- 2
1994 Evinrude 70 hp rebuilt six months ago. Took VRO off. Removed oil line, oil reservoir and wiring. Capped off oil intake at fuel pump. Obviously premix now. Engine has been running great except that after a couple of minutes at +/-4800 rpm I start losing power. If I squeeze the priming bulb the rpm's pick back up for a minute then start losing rpm again. Happens at all rpm, just happens sooner at higher rpm. Fuel system is completly new: fuel lines, fittings, racor water separator, suction stem in tank, priming bulb. Fuel pump is the original. Priming bulb fills easily and stays firm when engine is off so I doubt I have a fuel delivery problem to the fuel pump. Any ideas? Please help.
