Hello!
I want to put a 1973 Johnson 85hp (20inch shaft length, mod#85393m) powerhead on a 1977 Evinrude 85hp (mod# 85799s, 20 inch shaft length) exhaust housing and lower unit. From what the marine engine (.com) website says, both motors use the same powerhead gasket. So this will work, right? I've read thru a few other posts but this particular case was not covered or wasn't clear to me... 20 shaft = long shaft, right? I am aware that the crank, rods etc are different between the two motors.
Thanks!
DW
Thanks!
DW
