Hey,
So I need to replace the water impeller on my outboard but I dont know how to remove the lower unit on my motor. Any help or sugestions will be much apreciated.
-Kudos
There should be a square cover plate halfway down the top part of the leg starboard side, attached with 2 small screws. Here's an image I found if it circled:
I recently pick up a '54 Evinrude 2 stroke 15 hp and am looking for parts. Funny though the latest year I can find is '55. Does anyone know what major changes that Evinrude made to the '55? Also will '55 parts fit the '54? Thanks
Your question is best answered by starting your own thread. Plus, there is a rule around here about hijacking threads, and digging up threads that are more then 3 months old. You may want to read the forum rules here; http://forums.iboats.com/forum-rules-guidelines/forum-rules-397820.html
When you are through and reconnect the shift rod make sure that you have the notch in the shift rod in perfect alignment with the opening in the clamp or you will wipe out the threads on the clamp screw.
